Fail to replace Audacity. [SOLVED]
юра00
Re: Fail to replace Audacity.
Post by юра00 » Tue Mar 07, 2017 3:59 pm
Imagine, I've downloaded the program, just deleted it without unpacking, and I can not restore it from the recycle bin because of this message. How can it be? Please, correct.
Post by Gale Andrews » Tue Mar 07, 2017 7:38 pm
юра00 wrote:Imagine, I've downloaded the program, just deleted it without unpacking, and I can not restore it from the recycle bin because of this message. How can it be? Please, correct.
I think you need to correct it yourself, or download the file again. If you are restoring to Program Files you will need Administrator permission.
Windows problems on your computer are nothing to do with Audacity.
юра00
Post by юра00 » Tue Mar 07, 2017 8:01 pm
Well, I'll overinstall Windows through 2 weeks and overcheck the problem. Please, don't lock the topic.
юра00
Post by юра00 » Mon Mar 20, 2017 3:48 pm
I've reinstalled the system, the problem has been solved. The topic can be locked.
Re: Fail to replace Audacity. [SOLVED]
Post by Gale Andrews » Mon Mar 20, 2017 3:58 pm
юра00 wrote:I've reinstalled the system, the problem has been solved. The topic can be locked.
Thank you, I have marked the topic [SOLVED] and locked it.
