Hello! Looking for help with a DLL issue. Just download the newest version of Audacity to my new Windows 10 PC and and I'm getting this error. wxmsw30u_qa_vc_custom.dll and and wxbase30u_vc_custom.dll and wxmsw30u_core_vc_custom.dll. Any suggestions as to how I can fix this. I've tried YouTube and cant seem to find a video for this exact .dll issue. PLEASE HELP!
Thanks in advance.
Chris
wxmsw30u_qa_vc_custom.dll ERROR
Re: wxmsw30u_qa_vc_custom.dll ERROR
I don't have any of those files on my computer...
Did you download Audacity and install from audacityteam.org?
Doug - I dont think I downloaded from this link. I will delete my files and re-try
- Quality Assurance
You could harm your computer if you download Audacity other than from http://www.audacityteam.org/download/windows. This is especially true if you download from an advertisement that claims it is what you said (the latest version of Audacity).
- Quality Assurance
If you don't then you would not be able to run Audacity. Those files are essential and shipped with Audacity.DVDdoug wrote:I don't have any of those files on my computer...
Sorry to cause confusion.. I guess something went wrong with my search.Gale Andrews wrote:If you don't then you would not be able to run Audacity. Those files are essential and shipped with Audacity.DVDdoug wrote:I don't have any of those files on my computer...
