What could happen? Is it just for me?
2.1.3-alpha-Feb 27 2017
Audacity began to work slowlier [SOLVED]
- Quality Assurance
Re: Audacity began to work slowlier.
Please provide more details of the problem. What function exactly is slower?
Export, import, effects.
- Quality Assurance
Which alpha version were you using before that was not slow?юра00 wrote:Export, import, effects.
I don't see any repeatable difference. Processing times can vary greatly depending on what other tasks your computer is doing at the time.
I don't remember. Maybe, my computer problem?
Re: Audacity began to work slowlier [SOLVED]
Yes, the problem was in my computer. I've updated Windows and everything became fine.
