*crash*
Rick944S
*crash*
Post by Rick944S » Tue Feb 07, 2017 5:50 pm
Hi Audacity crashes when working with Spitfish De-esser
Win 7 64
Audacity 2.1.2
installed today via exe installer
Thanks
Rick
Re: *crash*
Post by Gale Andrews » Tue Feb 07, 2017 6:37 pm
Rick944S wrote: Win 7 64
Audacity 2.1.2
Thanks for the report, Rick.
Spitfish does not crash for me on Windows 10.
Do you have any exact steps we could follow to reproduce the crash?
Rick944S
Re: *crash*
Post by Rick944S » Tue Feb 07, 2017 10:04 pm
Yeah Gale, it happens when I click the play/stop preview > button. Not always, just after a few times, this is with a ~10 second selection. I am usually in listen mode also.
Thanks for the fast response!
While we are there, I don't see any presets named, they all say "none" but each produce a different setting.
Re: *crash*
Post by Gale Andrews » Wed Feb 08, 2017 2:53 pm
Rick944S wrote:Yeah Gale, it happens when I click the play/stop preview > button. Not always, just after a few times, this is with a ~10 second selection. I am usually in listen mode also.
I could get it to crash once if I pumped the Play/Stop button in the effect as fast as I could. I wouldn't call that normal usage.
Have you changed the effect's options (Manage button > Options...)? Does reducing the buffer size make it more stable?
Did you use Spitfish before in a previous version of Audacity without crashes?
There are a few other free De-essers such as Lisp.
Rick944S wrote:I don't see any presets named, they all say "none" but each produce a different setting.
That's how the effect is as far as I know - it has been left undeveloped for the last 10 years or so.
If you find a factory preset you like, select it, then save it as a user preset (Save Preset...).
Rick944S
Re: *crash*
Post by Rick944S » Sat Feb 11, 2017 5:34 pm
I halved and quartered the buffer size and it helped a little at 4096 but still crashes. Strange that no others have this problem. You are testing in Win 10 huh? I guess it's getting close to upgrade time.
Thanks
janetcstriebel
Re: *crash*
Post by janetcstriebel » Wed Jul 25, 2018 12:49 pm
Hello,
I'm having the same problem as Rick. I have Windows 10.
I have Audacity 2.1.3 and just installed spitfish.
When trying to apply changes, or hitting the "play" button my Audacity program halted/crashed many times and I had to recover the project. These were the messages I received:
Code: Select all
0:12:06: Audacity 2.1.3
20:12:06: Trying to load FFmpeg libraries...
20:12:06: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
20:12:06: Looking up PATH environment variable...
20:12:06: PATH = 'C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\rjjin\AppData\Local\Microsoft\WindowsApps;'
20:12:06: Checking that '' is in PATH...
20:12:06: FFmpeg directory is in PATH.
20:12:06: Checking for monolithic avformat from 'avformat-55.dll'.
20:12:06: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
20:12:06: Loading avutil from ''.
20:12:06: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
20:12:06: Loading avcodec from ''.
20:12:06: Loading avformat from 'avformat-55.dll'.
20:12:06: Error: Failed to load FFmpeg libraries.
20:12:06: Error: Failed to find compatible FFmpeg libraries.
Still researching what to do next. I would greatly appreciate any feedback anyone has for this matter.
Janet
Reason: code tags added to improve readability
Re: *crash*
Post by steve » Wed Jul 25, 2018 1:33 pm
Please try upgrading to the current version of Audacity (2.2.2). You can get it via the Audacity website: https://www.audacityteam.org/download/windows/
Does the crash occur only when Spitfish is open?
janetcstriebel
Re: *crash*
Post by janetcstriebel » Thu Jul 26, 2018 1:03 am
Yes, the crash only happens when Spitfish is open. This has never happened before. The first time was when using Spitfish.
Re: *crash*
Post by steve » Thu Jul 26, 2018 8:23 am
Does your Spitfish plug-in have a version number?
Perhaps there's an earlier version of Spitfish that works, and a later version that doesn't (?)
waxcylinder
Re: *crash*
Post by waxcylinder » Thu Jul 26, 2018 9:06 am
Spitfish works for me on 2.2.2 and the latest 2.3.0 alpha on W10 - no crash
And it works for me too on 2.1.3 - the version that Janet was using.
My Spitfish version is 1.1
