yet another thing Ill have to remem for the future
anyway, thanks for all the help.... Im finally sorted !
recording internally [SOLVED]
stardust2003
- Quality Assurance
Re: recording internally [SOLVED]
Good, I will mark this as [SOLVED] then and lock the topic.stardust2003 wrote:Im finally sorted !
