Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
ecloev
Post
by ecloev » Sun Jan 15, 2017 7:11 pm
Hey,
When I'm recording audio there is a ringing noise in the background.
It's not static but a high pitched ring? How can I get rid of this?
I've attached an example (The pure background noise with no voice).
I have already tried noise reduction in effects.
Thanks
Post
by kozikowski » Sun Jan 15, 2017 7:29 pm
What's the microphone? Blue Yeti? Windows laptop?
Trebor
- Operating System: Windows 8 or 8.1
Post
by Trebor » Sun Jan 15, 2017 10:44 pm
ecloev wrote:When I'm recording audio there is a ringing noise in the background.
Applying notch filters can remove the constant noise ...
Code: Select all
(setf s (notch2 s 60 10)) ; apply 60 Hz notch
(setf s (notch2 s 500 10)) ; apply 500 Hz notch
(let* ((q 50) ; set the base Q for the filter
(freq 1000) ; set base frequency
;set the number of iterations
(iter (truncate (/ *sound-srate* (* 2 freq)))))
(dotimes (i iter s) ; start the DO loop
(setf s (notch2 s (* freq (1+ i)) (* q (1+ i))))))
- Notch-filter code in Audacity's ''Nyquist Prompt''.png (12.45 KiB) Viewed 894 times
ecloev
Post
by ecloev » Sun Jan 15, 2017 10:46 pm
kozikowski wrote:What's the microphone? Blue Yeti? Windows laptop?
It's a Steelseries Arctis 5.
ecloev
Post
by ecloev » Sun Jan 15, 2017 10:47 pm
Trebor wrote:ecloev wrote:Hey,
Code: Select all
Example, Before-After Notch-Code.wav
Didnt work.
Post
by kozikowski » Mon Jan 16, 2017 12:09 am
My Logitech headset does that and I've never been able to solve it.
The microphone makers claim the noise is below -60dB so it's not their problem. It's true that's the AudioBook standard, but that's also assuming a rain-in-the-trees, water-on-the-beach white noise that's easily ignored, not a tea kettle whistle.
It sounds like data leaking into your microphone. It's a cousin to The Yeti Curse. Blue Yeti performance microphones can have the same problem. We've never found a fix past stop using the headset or Yeti.
ecloev
Post
by ecloev » Mon Jan 16, 2017 2:20 am
kozikowski wrote:My Logitech headset does that and I've never been able to solve it.
Right, but isn't there something I can do to remove the high frequency noise from the audio?
Why can audacity remove static but not this noise?
Post
by kozikowski » Mon Jan 16, 2017 5:51 am
We can't take out static, either. We can suppress hiss (ffffffff) and any other single constant noise. I'm betting we can suppress your whistle but we can't make it vanish, pretty much the exact same problem with the Yeti microphone. It's like trying to filter out kid screaming on a jet/fingernails on blackboard.
Oh, while we're doing this, it's best to perform an actual test sound clip. Posting a straight line is interesting, but it doesn't always tell us The Whole Story.
http://www.kozco.com/tech/audacity/Test ... _Clip.html
- Site Admin
Post
by steve » Mon Jan 16, 2017 11:01 am
ecloev wrote:Didnt work.
You need to be more specific. Did it give an error? Did your computer catch fire? Did it remove the hum and squeal but not the other mess?
The code that Trebor posted uses legacy (version 3) syntax, so you need to select that option in the Nyquist Prompt.
Trebor
Post
by Trebor » Mon Jan 16, 2017 1:56 pm
steve wrote:The code that Trebor posted uses legacy (version 3) syntax, so you need to select that option in the Nyquist Prompt.
i.e. tick the box I colored yellow ...
Then apply "
Nyquist Prompt" to the audio like any other Audacity effect.
