Saving multiple channels in one OGG file [CLOSED]
Roadhog360
So, I've been trying to save an OGG file with multiple channels.
Basically, I am trying to edit this OGG file, but can't get it to save the way it was.
When I open the file, I get this:
https://cdn.discordapp.com/attachments/ ... pture2.PNG
So, I select everything and press OK.
https://cdn.discordapp.com/attachments/ ... apture.PNG
Now, as you can see, there are two channels visible in this screenshot (In total there's about 18).
Each one has a different song.
What I am trying to do is save the OGG the way it was by having those multiple channels.
Every time I save through exporting, it 'squashes' all 18 or so channels into one, causing it to be one glob of about 18 songs at once.
If I save through export multiple, it saves each channel as a separate OGG file.
How can I save the channels/indexes in the OGG file like it was when I opened it?
I saw a thread about this, but it didn't get a good answer, so I'm here to explain it in more detail. Person also said it was MOGG, but the format is actually OGG.
The person who replied also said to go to a gaming forum, but didn't link any forums or anything, so it wasn't very helpful.
Roadhog360
Re: Saving multiple channels in one OGG file
Actually, I'll opt for other formats that have multiple channels like this, I'll try to convert it back and report my results here.
To create a multi-channel file (more than 2 channels), you need to enable the "Use custom mix" option in Preferences.
See: http://manual.audacityteam.org/man/impo ... ences.html
and then:
http://manual.audacityteam.org/man/adva ... tions.html
and then:
- Quality Assurance
It's up to you do to the research into the best forum, because if this is a MOGG file, Audacity does not support exporting as that (except for exporting multi-channel OGG). It depends where you are going to play the multi-channel OGG file that Audacity exports. It won't work in a game, if it came from a game in the first place.Roadhog360 wrote:I saw a thread about this, but it didn't get a good answer, so I'm here to explain it in more detail. Person also said it was MOGG, but the format is actually OGG.
Please don't misrepresent what I said. I mentioned Doom9 and AfterDawn forums.
Is there even an official specification for Mogg? Other than loads of pirate-ware, it only use seems to be used by Rock Band and Guitar Hero.
- Quality Assurance
That's the problem. MOGG files are usually encrypted if they come from Rock Band/Guitar Hero, so you've already had to use unofficial software to decrypt them into something Audacity can import. That's why you're probably going to have to dig deep into gaming forums, logged into a special area, if you want to figure how to repackage a MOGG after decrypting and editing it.steve wrote:Is there even an official specification for Mogg? Other than loads of pirate-ware, it only use seems to be used by Rock Band and Guitar Hero.
There is something about the MOGG-specific headers here: http://rockband.scorehero.com/forum/vie ... php?t=7128.
Roadhog360
It is an OGG, not an MOGG, and it came from a game, and the game reads the file this way.Gale Andrews wrote:That's the problem. MOGG files are usually encrypted if they come from Rock Band/Guitar Hero, so you've already had to use unofficial software to decrypt them into something Audacity can import. That's why you're probably going to have to dig deep into gaming forums, logged into a special area, if you want to figure how to repackage a MOGG after decrypting and editing it.steve wrote:Is there even an official specification for Mogg? Other than loads of pirate-ware, it only use seems to be used by Rock Band and Guitar Hero.
Roadhog360
Also, I just tried what you said, and it limits me to 32 channels and cuts off some of the game's channels even though the OGG file in the game only has 20.Gale Andrews wrote:It's up to you do to the research into the best forum, because if this is a MOGG file, Audacity does not support exporting as that (except for exporting multi-channel OGG). It depends where you are going to play the multi-channel OGG file that Audacity exports. It won't work in a game, if it came from a game in the first place.Roadhog360 wrote:I saw a thread about this, but it didn't get a good answer, so I'm here to explain it in more detail. Person also said it was MOGG, but the format is actually OGG.
They just only have odd numbers, here's the game's channels:
Code: Select all
1
3
5
7
9
11
13
15
17
19
21
23
25
27
29
31
33
35
37
39What I mean 'in a weird way' is, the channels of an odd number are copied to the next number to 'fill' in the even numbers with the previous odd number. So the channel 2 it created uses channel 1's audio, channel 4 uses channel 3's audio, etc, so it's copied over.Z
How can I fix this?
- Quality Assurance
If it's from a game as we suspected, it's a MOGG whatever it was renamed as.Roadhog360 wrote:It is an OGG, not an MOGG, and it came from a game, and the game reads the file this way.Gale Andrews wrote:That's the problem. MOGG files are usually encrypted if they come from Rock Band/Guitar Hero, so you've already had to use unofficial software to decrypt them into something Audacity can import. That's why you're probably going to have to dig deep into gaming forums, logged into a special area, if you want to figure how to repackage a MOGG after decrypting and editing it.steve wrote:Is there even an official specification for Mogg? Other than loads of pirate-ware, it only use seems to be used by Rock Band and Guitar Hero.
- Quality Assurance
To reiterate for you, Audacity supports multi-channel OGG files for playback in standard audio players.
Audacity has no way to package OGG or MOGG files that have non-standard headers and custom indices for use in games.
You may be able to "fix it" by going to the dark side of gaming forums.
Roadhog360 wrote:Also, I just tried what you said, and it limits me to 32 channels and cuts off some of the game's channels even though the OGG file in the game only has 20.Gale Andrews wrote:It's up to you do to the research into the best forum, because if this is a MOGG file, Audacity does not support exporting as that (except for exporting multi-channel OGG). It depends where you are going to play the multi-channel OGG file that Audacity exports. It won't work in a game, if it came from a game in the first place.Roadhog360 wrote:I saw a thread about this, but it didn't get a good answer, so I'm here to explain it in more detail. Person also said it was MOGG, but the format is actually OGG.
They just only have odd numbers, here's the game's channels:But it thinks it's 39 channels and only allows channels 1-32. It saves channels 1-32, but also has even numbered channels. In a weird way...Code: Select all
1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39
How can I fix this?
