Can no longer detect FFmpeg
charlieb000
Post by charlieb000 » Mon Jan 02, 2017 4:34 am
Split from http://forum.audacityteam.org/viewtopic ... 33#p319533
The only other issue I have with audacity (2.12) is that it says it cannot see my avformat-52.dll. But mp3 is good enough. Also tried 53. Tells me “failed to find compatible FFmpeg libraries”. Even dropped them into c:\
Re: Can no longer detect FFmpeg
Post by Gale Andrews » Mon Jan 02, 2017 2:27 pm
As this is unrelated to your topic about orphaned block files in long projects, I started a new topic for you.
charlieb000 wrote:The only other issue I have with audacity (2.12) is that it says it cannot see my avformat-52.dll. But mp3 is good enough. Also tried 53. Tells me “failed to find compatible FFmpeg libraries”. Even dropped them into c:\
We don't make "2.12". Always download Audacity from http://www.audacityteam.org/download/windows.
If you have upgraded to 2.1.2 from earlier than 2.0.6, you need to download the later FFmpeg 2.2.2 according to this FFmpeg FAQ.
Use the FFmpeg 2.2.2 installer "ffmpeg-win-2.2.2.exe", do not change the installation path then 2.1.2 should detect the new FFmpeg automatically.
