Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
abrogard
Post
by abrogard » Thu Dec 29, 2016 3:09 am
I have audacity 2.1.2
I don't remember if I got the zip or not.
All I want to do is make a small piece of vocal sounds, birdcalls maybe - for half a minute maybe - and then repeat that for half an hour
Then burn a cd of it.
can't figure out how to do it.
anyone can help?
ab
abrogard
Post
by abrogard » Thu Dec 29, 2016 10:43 am
Yes, i have seen that tool . I was using it. it played on and on fine - but I've got no indication of how to save it to a file.
I had to go before I got a chance to save that file - mean export to audio file of course, not save an audacity project - but I can't see that exporting the audio would do more than export that short selected clip - or the whole recorded track. But it can't save a one hour stretch of it, can it? without being told I want one hour.
and that's the point. where/when/how does it ask me how much I want of this repetition and then allow me to export it?
- Quality Assurance
Post
by Gale Andrews » Thu Dec 29, 2016 2:40 pm
If you Effect > Repeat... a selection, the selection is extended.
If you then File > Export Selected Audio..., you will export only the selection that you extended.
If you FIle > Export Audio..., you will export the entire track, including the extended selection.
abrogard
Post
by abrogard » Thu Dec 29, 2016 6:33 pm
Thank you. I was all wrong there. It wasn't the repeat tool I'd used. I don't know what. But the repeat tool gives you what I was looking for: somewhere to input how many repeats you want. I was into something to do with looping.
Anyway it's all fine now, my mistake.
Thanks very much.
