Some Nyquist plugins are not reflected in the View-History.
Equalization (one-band customizable), Band-stop filter, Comb filter, Stereo-widener. They are successfully applying, but not reflected. Please, correct.
2.3.1-alpha-Dec 5 2016
Re: Some Nyquist plugins are not reflected in the View-Histo
Where are the plug-ins?юра00 wrote:Equalization (one-band customizable), Band-stop filter, Comb filter, Stereo-widener
The same place where the rest:
C:\Program Files (x86)\Audacity\Plug-Ins
But the rest are reflected, and these - not. Why?
- Quality Assurance
We appreciate your reports, but as we have repeatedly asked you, PLEASE tell us the exact file name of the plugin (for example, "widener.ny") and exactly where to obtain the plugins you report.
If you don't do this, your report may be ignored, simply because we can't find the plugins to test them.
Tested on Windows 10 64-bit, "audacity-win-rf4a5805-2.1.3-alpha-17-dec-16.zip", Audacity run in English or Nihongo as chosen in Audacity Preferences, or run in "System" Language with Japanese language chosen in Windows "Region".
Is it this https://sourceforge.net/p/audacity/mail ... /14238040/? It appears in History for me.юра00 wrote:Equalization (one-band customizable)
If those are "Bandstop.ny" and "widener.ny" from http://wiki.audacityteam.org/wiki/Nyqui ... t_Plug-ins they appear in History for me.юра00 wrote:Band-stop filter, Stereo-widener.
If that is "comb_1190.dll" from the Steve Harris swh plugins, it appears in History for me.юра00 wrote:Comb filter
bandstop.ny, eqcustom.ny, widener.ny, comb.ny. But they don't appear in history for me.
I take issue off. Excuse me.
Audacity 2.1.3 alpha ?юра00 wrote:2.3.1-alpha-Dec 5 2016
What does that mean? Was it "user error" (not a bug)?юра00 wrote:I take issue off.
2.1.3 certainly. Yes, it was my error.
Some Nyquist plugins are not in the View-History.[CLOSED]
Thanks for confirming. I'll close this topic.
