Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Mon Dec 26, 2016 1:52 pm
hallert wrote:The last time this incident occurred I went away for 10 minutes. When I returned, the little blue circle was still spinning and the 'not responding' message was still there.
That sounds like you were running an effect or doing something when you left that was still completing when you came back.
When you install 2.1.2, half way through installation, you will see a checkbox "Reset Preferences". Check (tick) that box. When you launch Audacity, say yes to resetting preferences. That might help.
