Creating and Selecting Labels
Ted R Brown
Audacity 2.1.0
Windows 7 X64
In trying to create a label to add at a selection point, or add a label at a playback position, the shortcut CTRL + B nor CTRL + M create a Label.
I have used this in times past.
Confused.
Windows 7 X64
Confused.
Re: Creating and Selecting Labels
The two commands are similar in that they both create labels:
CTRL + M: Creates a new, empty label at the current playback or recording position.
Use this while playing or recording (or paused). This always creates a "point label".
CTRL + B: Creates a new, empty label at the cursor or at the selection region.
Use this to label a selection or the "cursor" position. Generally you would use this while playback is stopped. If there is a region selected, it creates a "region label", otherwise it creates a point label.
Tip: There's a full list of shortcuts in the manual: http://manual.audacityteam.org/man/keyb ... rence.html
Ted R Brown
Thanks for your response.
I've been using labels for almost two years. But today...I can't create. Your thoughts why?
Ted
Ted
Perhaps the Ctrl key on your keyboard is sticking?
Ted R Brown
I see you don't have a workable solution. I trust someone else has had this problem and can offer a solution.
Thanks for trying.
Thanks for trying.
What happens if you do this:
1) Start Audacity, or if already running, exit Audacity and restart.
2) Generate > Tone
Waveform: Sine
Frequency: 440
Amplitude: 0.8
Duration: 30 s
3) Ctrl+B
2) Generate > Tone
Waveform: Sine
Frequency: 440
Amplitude: 0.8
Duration: 30 s
3) Ctrl+B
Ted R Brown
My Tone Settings were set as you suggested.
I downloaded V 2.1.0 on 11/30/16.
Yesterday, 12/12/30 was the first time I attempted to Create a Label on V2.1.0. The FIRST label was generated. The second and all other attempts were not.
I believe in my chain, I may have a conflict with USB ports. I.E. a 3.0 USB hardware in a 2.O port or vice versa.
Today, I will uninstall V2.1.0 and reinstall V2.0.5 as all was working well with V2.0.5.
I'll keep you in the loop. Thanks for your direction.
Ted
Ted
- Quality Assurance
This is our site: http://www.audacityteam.org/download/windows. 2.1.2 is the current and recommended version.
Did you label the tone successfully? No-one else has this problem, as far as I know. But in 2.1.2, you won't be able to label a selection while dragging it with the mouse.
Ted R Brown
Version 2.1.2 has solved my problem.
Thank you all very much.
