Help! I can't hear what audacity is getting...
drad dog
Post by drad dog » Mon Nov 28, 2016 10:39 pm
I am playing my cassette machine in through the line in 1/4 in port and audacity is getting a level. It records in mono. I see the level but I can't hear anything until it plays back the recorded piece!
Can someone help me configure my audacity and to hear what it'g got a level for? And can it record in stereo? I am missing some knowledge on configuring this.
Thanks
Re: Help! I can't hear what audacity is getting...
Post by kozikowski » Tue Nov 29, 2016 1:18 am
Could you mean the 1/8" socket like this.
If you have a newer machine, you may only have one hole instead of two...or three. If you do only have one, you will not be able to use it to record stereo.
Is that what you have?
DVDdoug
Forum Crew
Post by DVDdoug » Tue Nov 29, 2016 3:17 am
Software Playthrough
For good quality and stereo, you need to use the line-input (not the mic input) on your soundcard. If you've got a laptop, you probably need a USB audio interface with line inputs.
