Windows 10 Audacity 2.1.0 exe installer
I have been using sounfinder to break up long recordings of several songs, but it sometimes breaks up a song into many small mp3 files. Once i have run soundfinder is there an easy to manually go in and modify what it thinks is a complete song?
Modify the results of Soundfinder
Re: Modify the results of Soundfinder
You may need to set the first control to a more negative value, and/or increase the value of the second control.
For more information, see: http://manual.audacityteam.org/man/sile ... inder.html
- Quality Assurance
Also the current Audacity version is 2.1.2: http://www.audacityteam.org/download/windows. Always download Audacity from there.
