I'm using a logitech webcam that has a microphone to skype and audacity to record the audio while using skype.
My good condenser mic is running through a komplete 6 audio interface and sounds great.
Problem is, audaicty uses the logitech mic even when the Komplete interface is selected.
This has to be an issue with the way audacity selects default audio sources.
I assure you I've selected my good mic interface in audacity. It switches by itself. Please help. Thanks!
Webcam Mic supersedes my good one
JackFrasier
- Operating System: Windows 7
Re: Webcam Mic supersedes my good one
It switches according to what Skype wants. Skype became the most reliable and respected communications program on earth by being vicious and brutal about getting its way.It switches by itself.
We recommend using a Skype-compliant program to record your works instead of trying to use Audacity. In a contest between Skype and Audacity, we haven't got a chance.
Pamela.
http://www.pamela.biz/en/products/
I think Voicemeeter can do this.
http://vb-audio.pagesperso-orange.fr/Vo ... banana.htm
Other offerings.
http://forum.audacityteam.org/viewtopic ... 91#p251167
JackFrasier
Re: WEbcam Mic Supercedes my good one
Thanks for responding,
but Skype isn't the thing that's switching.
It's audacity.
Even though the audio interface is selected, it defaults to the logitech mic in the webcam.
It's audacity.
Which microphone does Skype use?
JackFrasier
On skype I'm using the Komplete 6 audio interface with my condenser mic.
That's all good.
But my plan was to run audacity in tandem and use the same mic at the same time.
I managed to do it, but I have to unplug my webcam.
That's all good.
I think you can disable it in "windows recording devices", rather than having to physically unplug it.JackFrasier wrote:... I have to unplug my webcam.
- Quality Assurance
What version of Audacity are you using? See Help > About Audacity... .JackFrasier wrote:On skype I'm using the Komplete 6 audio interface with my condenser mic.
That's all good.
Were you explicitly selecting the audio interface by name as Audacity recording device? If you choose a mapped device then you use whatever is Windows default recording device.
And if you are only recording the mic (your side of the conversation), how are you recording the other party? Or is the other party being sent to the interface?
