Fadeout command in edit chains [SOLVED]
jeremyxwilson
- Operating System: Windows 8 or 8.1
Hi -- I would like to trim silence from hundreds of MP3 files (using chains) and apply a fadeout to the end. I found the trimsilence plugin and it works great. But how can I accomplish the fadeout? It seems to default to the whole audio, but I want it to fade for the last few seconds. Thanks.
- Quality Assurance
Re: Fadeout command in edit chains
Chains applied to files cannot specify the selection. Do you want to vote for that improvement?
I know of http://forum.audacityteam.org/viewtopic ... 96#p267196 which fades in a given selection length at the start and fades out the same selection length at the end by the same amount.
Perhaps Steve here will adapt that for you if he has time.
jeremyxwilson
Thank you. I think that will solve my problem.
If you need to modify the code for your task and need help doing so, feel free to ask.jeremyxwilson wrote:Thank you. I think that will solve my problem.
jeremyxwilson
Thanks! All the files are processed now.
Re: Fadeout command in edit chains [SOLVED]
Thanks for letting us know.jeremyxwilson wrote:Thanks! All the files are processed now.
I'll mark this topic "solved".
