pause button issue
benbernie
pause button issue
Post by benbernie » Wed Oct 19, 2016 11:01 am
hi
when I record an lp ill just start the record playing hit the record button and just let it go..i just let it record on its own till the record is finished..ive been seeing that somehow the "pause button gets pushed without me touching it.this is the 2nd time it get pushed with out me touching it..why is this happening?
benbernie
Re: pause button issue
Post by Gale Andrews » Wed Oct 19, 2016 12:18 pm
If you touch the P key on your keyboard by accident this will activate Pause. P is the shortcut for Pause.
If you want, you can go to Edit > Preferences..., Keyboard section. Type "pause" (without quotes) in the Search box. Then click on "Pause" in the list to select it and press the Clear button. Then pressing P on your keyboard will not Pause.
benbernie
Post by benbernie » Wed Oct 19, 2016 12:31 pm
thanks
benbernie
Post by benbernie » Fri Oct 21, 2016 4:32 pm
ok this time the pause button wasn't activated..the wave editor just stiopped recording.......I didn't touch any button except the record button..and it stopped operation almost at the end of the side of the record..what can I do now?
benbernie
Post by Gale Andrews » Fri Oct 21, 2016 6:55 pm
If it's a USB turntable, disconnect and reconnect the USB cable and make sure it is tight at both ends. Also consider changing the cable.
Then reboot your computer.
Make sure Transport > Sound Activated Recording is not selected (not ticked).
benbernie
Post by benbernie » Fri Oct 21, 2016 7:28 pm
hi
no its a non usb turntable..
benbernie
DVDdoug
Forum Crew
Post by DVDdoug » Fri Oct 21, 2016 8:02 pm
...almost at the end of the side of the record.
If it happened during the fade-out, is it possible that you've selected the sound activated recording option?
what can I do now?
Record the last song again? :P
benbernie
Post by benbernie » Fri Oct 21, 2016 8:36 pm
ok thanks
