Adding Timestamps while Recording [SOLVED]
Darkcell
Post by Darkcell » Wed Oct 12, 2016 4:55 am
Hello, so my question is if there is a way to add time stamps or "bookmark" certain points of the audio while I'm recording. Sometimes I record me and my friends while were playing, to get some funny reactions, so I would like to be able to return to those points when I'm done recording it.
Re: Adding Timestamps while Recording
Post by kozikowski » Wed Oct 12, 2016 10:10 am
You can hot-key create a label while you're recording.
http://manual.audacityteam.org/man/label_tracks.html
Darkcell
Re: Adding Timestamps while Recording [SOLVED]
Post by Darkcell » Thu Oct 13, 2016 6:04 pm
Thanks! Works like a charm
