Effects do not load settings
юра00
Re: Some problems, applying Bass and Treble.
Post by юра00 » Thu Oct 06, 2016 4:44 pm
Earlier all was fine with the same effect values.
Re: Effects do not load settings
Post by Gale Andrews » Fri Oct 07, 2016 12:05 am
Leveler has now been removed from 2.1.3-alpha. It is a mistake that it is still available in the Effect Menu, but that problem is logged at http://bugzilla.audacityteam.org/show_bug.cgi?id=1453.
I don't have a problem running the Nyquist Comb filter or Nyquist Pseudostereo in Oct 4th 2016 2.1.3-alpha after doing so in 2.1.2 release or 15 Jun 2016 2.1.3-alpha. If you do, I think the problem will only occur when you first launch the effect.
If the problem continues, exit audacity and delete the file Users\<your username>\AppData\Roaming\Audacity\pluginsettings.cfg.
If the problem continues after that, please give us the exact file name of the plugins and tell us where you obtained them from, and tell us what language Windows is running in and what language Audacity is running in (look in Interface Preferences).
юра00
Serious problem for many effects-Nyquist plugins, leveller.
Post by юра00 » Fri Oct 07, 2016 7:22 am
For instance, after applying band-stop filter appears:
Code: Select all
error: unbound variable - HELP
if continued: try evaluating symbol again
Function: #<FSubr-IF: #586de00>
Arguments:
  (= HELP 1)
  (VIEWHELP)
  (MULTICHAN-EXPAND (FUNCTION BANDSTOP) S FREQ WIDTH)
Arguments:
  (> (* FREQ (POWER 2 (/ WIDTH 2))) (/ *SOUND-SRATE* 2))
  (PRINT "Error.\nFrequency or bandwidth too high.")
  (IF (= HELP 1) (VIEWHELP) (MULTICHAN-EXPAND (FUNCTION BANDSTOP) S FREQ WIDTH))
1>
The same picture for many ofther effects. Earlier everything was fine. What has happened? Please, help.
Audacity 2.1.3-alpha-October 4 2016.
юра00
Re: Serious problem for many effects.
Post by юра00 » Fri Oct 07, 2016 8:15 am
Effect Leveller is unapplicable:
Code: Select all
11:12:45: Audacity 2.1.3-alpha-Oct  4 2016
11:12:45: Trying to load FFmpeg libraries...
11:12:45: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
11:12:45: Looking up PATH environment variable...
11:12:45: PATH = 'C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static'
11:12:45: Checking that '' is in PATH...
11:12:45: FFmpeg directory is in PATH.
11:12:45: Checking for monolithic avformat from 'avformat-55.dll'.
11:12:45: Error: Failed to load shared library 'avformat-55.dll' (error 126: не найден указанный модуль.)
11:12:45: Loading avutil from ''.
11:12:45: Error: Failed to load shared library '.dll' (error 126: не найден указанный модуль.)
11:12:45: Loading avcodec from ''.
11:12:45: Loading avformat from 'avformat-55.dll'.
11:12:45: Error: Failed to load FFmpeg libraries.
11:12:45: Error: Failed to find compatible FFmpeg libraries.
11:12:48: File name is C:\Users\Юрий\Music\11 маршрут1.mp3
11:12:48: Mime type is *
11:12:48: Opening with libsndfile
11:12:48: Opening with libmad
11:12:48: Open(C:\Users\Юрий\Music\11 маршрут1.mp3) succeeded
Post by Gale Andrews » Fri Oct 07, 2016 1:39 pm
I merged your last two posts in "Adding Features" into this topic. Please stay in this topic if you want to discuss this further.
Have you read my previous reply?
юра00
Post by юра00 » Fri Oct 07, 2016 3:22 pm
I have deleted the file Users\<your username>\AppData\Roaming\Audacity\pluginsettings.cfg. - doesn't help. System language Russian, programm language English. Earlier everything was fine, only since some alpha version. I've chanhged nothing - programm location, settings... What has happened?
http://wiki.audacityteam.org/wiki/Downl ... s#download
http://gaclrecords.org.uk/win-nightly/
I've downloaded, as everybody. In this version: audacity-win-re26d7c6-2.1.3-alpha-19-jun-16 - everything is fine.
Post by Gale Andrews » Fri Oct 07, 2016 5:11 pm
юра00 wrote:I have deleted the file Users\<your username>\AppData\Roaming\Audacity\pluginsettings.cfg. - doesn't help. System language Russian, programm language English.
The "cannot load settings" only occurs the first time I use the plugin, if I change Windows Region and Language format to Russian, or if I then change Audacity language to English.
If I delete audacity.cfg, the problem does not happen at all, with Russian still set in Windows and if I do not change Audacity language.
Are you saying the "cannot load settings" continues every time you use the plugin? Does the plugin appear after the warning and can you then use the plugin? If so, what decimal separator appears in those Nyquist effects - comma or decimal point? Also look at the other effects such as Wahwah or Phaser. Are those showing comma or decimal point separator? I think they should show decimal point separator, with Windows language in Russian and Audacity language in English.
What happens if you change Audacity language to System? Do you still see "cannot load settings"? Do you then see comma separator in the effects?
юра00
Post by юра00 » Fri Oct 07, 2016 5:49 pm
Yes, continues every time. Certainly, changing programm languge to system doesn't solve the problem. Yes, the plugin appears after warning and I can use it, but it is uncomfortable. If programm language is English - decimal separator is always dot, if it is Russian (system) - always comma. Something wrong with the programm. If you'll find the computer with system language Russian, I am sure, you'll see the same anomalies and can reproduce the problem, which stops all my work.
Post by Gale Andrews » Fri Oct 07, 2016 10:41 pm
юра00 wrote:stops all my work.
Why does it do that? It is obviously annoying but does the plugin work correctly when you run it? Does it remember the same settings you used last time?
Is it only Nyquist effects that do this - not VST or LADSPA or any of the built-in effects?
юра00
Post by юра00 » Sat Oct 08, 2016 7:35 am
Yes, it works correcly and remaines last value, used, but only after warning every time. I don't know, use only Nyquist effects. The built-in effects work normally. It seems, I have understood. When I cause effect, the programm loads the values from other effect, certainly, they are unsuitable, and asks to overset them! Further, everything are working, but very uncomfortable. Correct, please!
