Stereo Issue
OneBadApple
- Operating System: Windows 7
Stereo Issue
Hello....I've been using Audacity with Windows Vista and 8.1 versions for years and love it. Retiring my old Korg 16-track recorder for recording music, today I downloaded Audacity into a laptop (Windows 7) and am accessing it via USB with a new Focusrite audio interface. No matter how many ways I try to configure the input choices, the audio will only record onto one (the right) of the two stereo tracks.
Monitoring the audio interface with headphones, everything sounds fine going in, but Audacity records it into only one channel.
Any suggestions will be much appreciated.
Thank you....
Doug in FL
Thank you....
Doug in FL
Re: Stereo Issue
Which model?OneBadApple wrote:accessing it via USB with a new Focusrite audio interface.
Most USB pre-amps give you two independent channels. Channel 1 being "Left" and channel 2 being "right". If you are using channel 2 as your input, then the device sends that as "right channel" to the computer.
OneBadApple
Re: Stereo Issue
Focusrite calls this their 'New Generation 2-in / 2-out Scarlett Solo. Input 1 is for mic only, and Input 2 for any instrument(s). Plugging a 2-channel drum machine (adapted to one 1/4" phone plug) into Input 2 sounds great using headphones and the Focusrite monitor, but records only to the right side in Audacity 'stereo" mode. If I change Audacity to 'mono', it hears nothing.
I can't imagine Focusrite designing an interface which recognizes both left and right sound going in (through Input 2), but would only send one side (via the USB output) to one recording channel. Finished recordings would of course be useless with all of the music on one side, and nothing but vocals (recorded through Input 1) on the other ....
Re: Stereo Issue
With ASIO drivers it is possible to allocate which channel each input goes to, but Audacity cannot be distributed with ASIO support due to licensing restrictions, so in Audacity you will be using the Windows drivers, which do not support channel mapping. Therefore input 1 always goes to the left and input 2 to the right.
To record just the right channel in Audacity (which is of course a mono input), set Audacity to record 2 channels stereo (in the device toolbar), then after recording, split the stereo track to mono, and delete the empty track by clicking on the [X] in the top left corner of the track.
OneBadApple
Re: Stereo Issue
First, thank you for both very prompt replies. I printed your text, as well as the information in the links.
This looks relatively easy to achieve, and you saved me a lot of time, head-scratching, and aggravation today.
Thanks very much....
Doug
Doug
Re: Stereo Issue
In the next version of Audacity there's a 'slightly' easier way, which is to create two mono tracks first, and then record into them (so avoiding the need to split the stereo track).
Not relevant now, but as a point of interest, I've been talking today with one of the developers about the possibility of selecting just channel 2 as the recording input. I think it's quite possible that we could have that in a later version, which would be nice and convenient for devices like the Scarlett Solo, but that's for the future.
- Quality Assurance
Re: Stereo Issue
Do you mean Append Record, Steve? But why does that not work in the current 2.1.2?steve wrote:In the next version of Audacity there's a 'slightly' easier way, which is to create two mono tracks first, and then record into them (so avoiding the need to split the stereo track).
Re: Stereo Issue
Does it work for 2.1.2? I don't know, I don't have a copy handy. I know it works for 2.1.3 alpha.Gale Andrews wrote:But why does that not work in the current 2.1.2?
- Quality Assurance
Re: Stereo Issue
If we are talking about Append Record (SHIFT + R), yes it should work fine ever since we had that feature. Either select both mono tracks, or none of them, then Append Record should record in both tracks.
Re: Stereo Issue
What got you here, is that direct monitoring is mono. So you hear one channel in both ears.OneBadApple wrote:Focusrite calls this their 'New Generation 2-in / 2-out Scarlett Solo. Input 1 is for mic only, and Input 2 for any instrument(s). Plugging a 2-channel drum machine (adapted to one 1/4" phone plug) into Input 2 sounds great using headphones and the Focusrite monitor, but records only to the right side in Audacity 'stereo" mode. If I change Audacity to 'mono', it hears nothing.
There is no real stereo input, hence the name "Solo". The left input is mic level (and line level with the gain at minimum), the right channel is a mono instrument input.
To record stereo, you need a custom cable, with a male XLR on one side and a 6.35 mm TR jack on the other side. That cable would end in whatever fits your drum machine, presumably a 6.35 mm TRS stereo jack. I'm prettu certain this kind of cable isn't available in the shop. Still, these mono inputs have different impedance and might sound a tiny bit different, depending on the source.
The Scarlett 2i2 would have avoided this problem completely, as it has a stereo input.I can't imagine Focusrite designing an interface which recognizes both left and right sound going in (through Input 2), but would only send one side (via the USB output) to one recording channel. Finished recordings would of course be useless with all of the music on one side, and nothing but vocals (recorded through Input 1) on the other ....
