Modulate sine tones.
GlenLivet21
Operating System: Windows 7
Tone and multi tone with am and fm modulation.
Post by GlenLivet21 » Mon Sep 26, 2016 6:34 pm
Is it easily possible to generate a sine tone and then apply am and fm modulation to it? Lets say I want a 500 hz tone that vibrates between 450 and 550 hz with 5 hz fm and am. How would I go about in audacity to do this? One hour googling gave no answer.
GlenLivet21
Post by GlenLivet21 » Mon Sep 26, 2016 6:37 pm
How to fm and am modulate a sine tone?
Re: Modulate sine tones.
Post by steve » Mon Sep 26, 2016 6:40 pm
Modulation takes two signals. Are you wanting to modulate two sine tones, or one sine tone with some other signal?
Post by steve » Mon Sep 26, 2016 6:47 pm
Topics merged.
GlenLivet21
Post by GlenLivet21 » Mon Sep 26, 2016 6:55 pm
steve wrote:Modulation takes two signals. Are you wanting to modulate two sine tones, or one sine tone with some other signal?
I want to modulate one sine with another sine. Both am and fm.
Post by steve » Mon Sep 26, 2016 6:55 pm
Amplitude modulation is easy. You just "multiply" the two tones. You can do this using the Nyquist Prompt effect (http://manual.audacityteam.org/man/nyquist_prompt.html).
To amplitude modulate any selected audio with, say a 5 Hz sine tone, use this code:
Code: Select all
(mult *track* (hzosc 5))
For frequency modulation, it is easiest to generate both the carrier and the message. For example:
"I want a 500 hz tone that vibrates between 450 and 550 hz with 5 hz"
Code: Select all
(hzosc (sum 500 (mult 50 (hzosc 5))))
Post by steve » Mon Sep 26, 2016 6:56 pm
For AM, generating both the carrier and the message:
Code: Select all
(mult (hzosc 500)(hzosc 5))
Post by steve » Mon Sep 26, 2016 6:59 pm
A slightly different (a bit more complex, but more "normal") version for AM:
Code: Select all
(mult (hzosc 500) 0.5 (sum 1 (hzosc 5)))
