Tracks Not in Order
Bruce Montany
Tracks Not in Order
I'm using Windows 10, Audacity 2.1.2 When I export multiple tracks to my Previous Itunes Libraries they are listed in alphabetical order. I always create a new folder of the albums name. I click and drag each track IN ORDER to the new folder. They still show up in alphabetical order. How do I change that? I want them in track order, just like the album.
Re: Tracks Not in Order
iTunes can create Playlists. In the playlist you can push music around as you wish. That's how iTunes creates the desired order to burn a Music CD if your computer can do that.
The command under File is "Burn Playlist to Disc."
