Missing Data Folders
drivvs
Operating System: Windows 7
Post by drivvs » Fri Sep 23, 2016 1:33 am
Hello,
I'm using Windows 7 and Audacity 2.1.2.
I've saved a number of Audacity projects before without issue. My most recently saved project now won't open. I first get a message saying that Audacity cannot find the project data folder, and then another message saying that it cannot open the file. I have not moved nor renamed any of the files, or done anything to any data file. I have tried searching my hard drive for the data folders, but they do not appear to be anywhere. Does Audacity ever fail to save a data folder or perhaps name it something odd or save it in an odd place? If the data files are not on my computer, is there anything that I can do to recover the project?
Thanks.
Re: Missing Data Folders
Post by kozikowski » Fri Sep 23, 2016 4:43 am
There is a condition where Audacity will stash work in a location where a virus protection program will "protect you" by deleting them. We should wait for a Windows elf.
Post by kozikowski » Fri Sep 23, 2016 4:47 am
This is an Audacity Project.
You would normally never need to know what's going on inside the _DATA folder. The AUP file is a computer program that tells Audacity what to do with all that stuff inside the _DATA folder. It's not a sound file.
The AUP file is written last, so if you have that and it's not blank (try to open it in a text editor such as NotePad or Text Edit), then Audacity seems to have succeeded in saving the Project.
Post by Gale Andrews » Fri Sep 23, 2016 12:41 pm
File > Recent Files top left of Audacity will show you the path where you saved recent projects.
