FADES
westy69
FADES
Post by westy69 » Thu Sep 22, 2016 5:49 pm
what the difference between a fade out and a crossfade out?
Re: FADES
Post by steve » Thu Sep 22, 2016 6:30 pm
westy69 wrote:what the difference between a fade out and a crossfade out?
"Fade Out" is an effect in the current version of Audacity. "Crossfade out" isn't.
I'm guessing that you're using an obsolete version of Audacity.
The current version of Audacity is available here: http://www.audacityteam.org/download/windows/
I'd recommend that you download the version that includes the Help files.
