track view changed [SOLVED]
JC3
Operating System: Windows 7
Post by JC3 » Mon Sep 19, 2016 10:59 pm
Hi, I made a track and did something that moved the track off center and expanded (widened (looks like amplify but I didn't amplify) the view of the track (its not louder just expanded wider than all other tracks) I fixed the off center problem but cannot figure out what I did that makes the appear amplified. any ideas? cheers
Re: track view changed
Post by steve » Mon Sep 19, 2016 11:42 pm
Perhaps you clicked on the vertical ruler at the left edge of the track? Doing so will zoom in vertically.
To zoom out, right click on the ruler, or "shift + right click" to zoom back to normal.
See: http://manual.audacityteam.org/man/audi ... html#scale
JC3
Re: track view changed [SOLVED]
Post by JC3 » Tue Sep 20, 2016 12:12 am
yes, that fixed it, resolved - ty
