Excuse the anger, I will try to contain my choice of words within whats reasonable.
I have a complaint about the "Export Selected" and also the general Export function:
When I edit an audio file, I edit it to perfection. When I export the audio file, I EXPECT to export the audio EXACTLY the way I edited it. This is unfortunately not the case. For some reason Audacity likes to add silences to the beginning of the audio file. Even when using the export selected function it still DOES NOT export EXACTLY what I selected.
Now you could say things like "audacity detects a user error as the audio file does not start from silence thus possibly generating a plop at the start of the sound". Well, if that were the case, I could add a small fade in myself easily enough with Audacity. However in my case my point was to create a simple SFX loop that I need (a machinegun firing loop which has to loop perfectly for a video game I'm making). It seems simply impossible to export exactly what I have in my project file. In audacity the loop sounds perfect (and looks), however when exported it is visibly and audibly changed from what was in my project. I'll add a screenshot as proof.
Unfortunately this means I now have to boot up my macbook and do it in Logic Pro. I use audacity to do quick and dirty audio editing every now and then (where I don't feel like waiting for my laptop and logic pro to boot up), but this exporting issue just baffles me.
