Microphone Problems
Roy Schreibe
Microphone Problems
Post by Roy Schreibe » Tue Sep 13, 2016 6:26 pm
Using Windows 10, connecting via a USB port, I recorded last week and my microphone worked fine. Today it won't work. I switched mics and still no luck. Any help greatly appreciated.
DVDdoug
Forum Crew
Re: Microphone Problems
Post by DVDdoug » Tue Sep 13, 2016 9:25 pm
Does the USB mic show up as your Recording Device? If not, right-click the Windows Speaker-Volume icon and select Recording Devices to see if it's showing-up there.
Roy Schreibe
Post by Roy Schreibe » Wed Sep 14, 2016 1:29 pm
Thanks for the advice. I rummaged around to find another mic to see if my rather new mic was the problem. It is.
Post by Gale Andrews » Wed Sep 14, 2016 2:16 pm
Roy Schreibe wrote:Thanks for the advice. I rummaged around to find another mic to see if my rather new mic was the problem. It is.
Or, the problem could be not the mic but the USB cable, if it has a detachable cable.
Roy Schreibe
Post by Roy Schreibe » Wed Sep 14, 2016 4:41 pm
The possibility of the cable occurred to me somewhat belatedly, that is after I ordered the new mic. I guess the test will come when I use the old cable on the new mic. Thanks for your help. I do appreciate it.
weldo5
Post by weldo5 » Thu Sep 15, 2016 1:09 am
Maybe the driver for the USB mic updated or it is incorrect?
