Recording button triggers Pause button
Im having a problem everytime i press the recordiing command the Pause command is automatically triggered and nothing is recorded, does anybody knows how to solve this problem
Re: Recording button triggers Pause button
Sounds like you've accidentally enabled "Sound Activated Recording (on/off)". Look near the bottom of the "Transport" menu and deselect that option.
