Select | Track-Layer(s) Split | Only SEL within each split
fohrums
Post by fohrums » Thu Sep 08, 2016 4:51 am
Code: Select all
Audacity_2.1.2_
Win10_Home_x64
How would I be able to select as-per splitted sections within a track-layer
according to Beginning (A) / End (B)? Understand that the track has multiple splitted sections within the track-layer, all of which are similar in length.
# EXAMPLE
https://s17.postimg.org/u2zkyukdb/Capture.jpg
___
## NOTE
* Audacity's Split-function doesn't label `Beginning / End` as `A / B` respectively
Re: Select | Track-Layer(s) Split | Only SEL within each spl
Post by Gale Andrews » Thu Sep 08, 2016 11:51 am
In what way is this different to http://forum.audacityteam.org/viewtopic.php?t=93016? What do you want to do to the labeled audio? There is no multiple select of separate regions except using Labeled Audio.
fohrums
Post by fohrums » Thu Sep 08, 2016 10:34 pm
Gale Andrews wrote:In what way is this different to http://forum.audacityteam.org/viewtopic.php?t=93016?
Rather than having the splitted-regions be put onto another track; instead, i'm
speaking on behalf of having those splitted-regions (the in-between's) be
selected (I understand this can only be done, if it's been processed by using `labeled audio`).
So, I want to be able to have each `splitted-regions` be selected. In my example
we're talking about more-than-1-by-a-bunch.
Hmm, in this-case I do have the regions made-split via `Labeled-Audio`. How
would I then be able to select *Them All*?
Post by Gale Andrews » Fri Sep 09, 2016 11:35 am
fohrums wrote:I do have the regions made-split via `Labeled-Audio`. How
Labeled Audio works on the audio of all labels that are encompassed by the selection you make in the Label Track. The selection remains the same after processing.
It would probably help if you said what you are trying to do. If you could select all the labels at once, which you can't, what would you want to do to those regions?
