Gale Andrews wrote:
It's probably `collapsed`.
* Collapse (all-tracks)
+ CTRL+SHIFT+C
* Uncollapse (all-tracks)
+ CTRL+SHIFT+X
This isn't the case, becuase I can't so-called `Uncollapse` the tracks that are already shrunken in size, but I have to agree that it is collapsed.....strange.
If that doesn't work then you have to manually re-size it:
+ Drag down at the bottom of a track to make it taller
Gale Andrews wrote:
Also you might want to turn on the Preference "Automatically fit tracks vertically zoomed" in
Tracks Preferences. Then the tracks won't be less than about half height, however many you have.
To have tracks stay consistently at a `Collapsed` size enable the following
option:
+ Preference -> Tracks -> Check `Automatically fit tracks vertically zoomed`
This isn't what I wanted. It makes the tracks smaller than the actual
default-view-size.
___
So manually changing the size is the only valid solution at the moment, which
is tought to deal with
