Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
fohrums
Post
by fohrums » Tue Sep 06, 2016 5:36 am
AUDACITY
* How to do a split
+ Edit -> Clip-Boundaries -> Split
depending on whether it's a `point` vs. `selection`
- `CTRL-I`
* Point vs. Selection
+ Point
A point will only be to where the cursor is placed and there isn't more than 1-cursor
+ Selection
To your current selection both the beginning-point & ending-point will be marked as splitted
DILEMMA
I want to be able to do the same `split` formatting to multiple tracks that are the same.
This is an extremely tedious process if the `split`-amount is like about 500-sectors.
EXAMPLE
https://s15.postimg.org/53tvm9fdn/Capture.jpg
___
NOTE
* Having the ability to duplicate `split-points` from one layer to another will be more helpful with a
keybind keyboard shortcut hotkey.
- Site Admin
Post
by steve » Tue Sep 06, 2016 10:19 am
fohrums wrote:I want to be able to do the same `split` formatting to multiple tracks that are the same.
Create "labels" at the places where you want splits to occur, then select the label track plus all of the tracks that you want to split, and apply "Edit > Labelled audio > Split".
See:
http://manual.audacityteam.org/man/edit ... audio.html
- Before
- tracks000.png (17.51 KiB) Viewed 249 times
- fullwindow001.png (100.53 KiB) Viewed 249 times
- After
- tracks001.png (17.75 KiB) Viewed 249 times
fohrums
Post
by fohrums » Thu Sep 08, 2016 5:00 am
SOLVED]
Thanks, Big-up, Safe, This help me fix the problem, Thank-You very much.
SUMMARY
* For each section you want to split
+ Start off by creating labels to represent each split
- then, select the whole label track-layer + the original track-layer(s)
you want to split
+ Edit -> Labeled Audio -> Split
- `Alt+I`
