Gale Andrews wrote:...Or if you are zoomed in, use DOWN arrow to move the yellow focus border into the label track, then TAB forwards through the labels or SHIFT + TAB to move backwards through the labels. This will move the view position to the label tabbed into, whereas Labels Editor does not move the view position to the selected label.
@Gale:
Thanks a lot for your replay!
I think, you mean the way, like I do this here in my short video --->
http://sendvid.com/8ic9qihe
That is a possibility with which the can be solved well. Unfortunately, it has 3 Disadvantages:
a) you can not see the audio track
b) I can not search for text labels
c) I have some many text labels that the space between themselves within the field of view is not enough. Then disappear the last text labels and can not be achieved. The track window is not expandable downward.
steve wrote:If you have a project with a very large number of labels, it can sometimes be easier to find a label using the Label Editor (
http://manual.audacityteam.org/man/labels_editor.html). Click on the label in the editor to move the cursor to that label position.
@Steve:
http://sendvid.com/bhsrw2rp
I have also this possibility in use. This is also very good, but also has also 3 disadvantages:
a) Unfortunately, the text editor has no shortcut
b) I can not search for text labels in the list
c) I can not play the selected audio without the editor must be closed complete
I checked here already because of this problem. My contribution is to be found at this location:
http://forum.audacityteam.org/viewtopic ... 56&t=86513
I had then published a screenshot:
http://forum.audacityteam.org/download/ ... p?id=13687
But it would be enough if to mark the text labels you could play with the software regular "Play button" the selected Audio section and not always have to close the complete editor.
If that is too difficult to implement, a shortcut for the "text editor" would be least helpful!
Thanks and regards,
Jürgen
