not recording the sounds in the physical room I'm in
soundy
Post by soundy » Thu Sep 01, 2016 1:57 am
Audacity 2.1.0
Windows 10
I'm trying to record the audio from a website where they are streaming using Flash version 22 with " JW Player" v7.6.1, and when I try to record it, I cannot get Audacity to record only the streaming audio, but the sounds in the physical room I'm in as well. How might I get around this?
thank you!
Re: not recording the sounds in the physical room I'm in
Post by kozikowski » Thu Sep 01, 2016 2:04 am
