what happened to the click track feature?
it used to be under the generate tab...I need to get some rhythm going on here
thanks
click track
lonepilgrim
Re: click track
It still is. http://manual.audacityteam.org/man/generate_menu.htmllonepilgrim wrote:it used to be under the generate tab
lonepilgrim
Re: click track
it`s not showing up on mine
with the last update I lost the click track..pluck and risset drum
it`s not there any more
Re: click track
I presume that you are on Windows 7 (as it says in your profile), so topic moved to the Windows board.
Look in "Edit > Preferences > Effects". Are "Nyquist" plug-ins enabled?
Assuming that they are, have you tried enabling Click Track using the plug-in manager?
