Upgrading from Old version will you lose files
KPM
Operating System: Windows 7
Post by KPM » Sun Aug 28, 2016 4:21 am
I have Windows 7. and Audacity 1.3 Beta
If I upgrade to the latest version will I lose all my files from the old version?
Re: Upgrading from Old version will you lose files
Post by steve » Sun Aug 28, 2016 9:26 am
Personally I don't encourage keeping Audacity projects as "projects", because (a) Audacity projects are huge, (b) it is essential that all of the audio data remains available for the project, (c) In old versions of Audacity it is not easy to see if the project is self contained or has "dependencies". If you intend to do further work on the project (more editing, processing, recording), then yes you should keep the project, but it is essential that the audio data for the project remains available to the project. When a project is completed, much better to keep a high quality WAV or FLAC file as the archive backup.
If the above is not totally clear to you, please see here for more information about Audacity projects: http://manual.audacityteam.org/man/auda ... jects.html
KPM wrote:If I upgrade to the latest version will I lose all my files from the old version?
Assuming that you mean "Audacity Projects", I'd suggest that you first check with your current version of Audacity that they are working correctly. If the projects are OK, then Audacity 2.1.2 will be able to open them.
Post by Gale Andrews » Sun Aug 28, 2016 12:36 pm
