My current main usage for Audacity is to record myself while I talk to a friend on Skype, I use this captured audio to create an m4a file of my voice which I send to my friend. He uses this with what he records of his voice and we make a simple podcast. I use a headset with mic attached to record and I have been picking up the person I talk to on Skype recently. What setting can I use to ensure I am capturing only my audio, or is it a matter of using an independent microphone separate from the speaker unit?
Second, and my most important pressing question, I have the raw audacity project of what I recorded, about 30 minutes of very soft audio of my friend abbreviated with my talking intervals which are of normal loud volume. Is there anything I can do with this file that I have now to separate out his very soft low audio out of the file, leaving behind the louder portions that are just me; with basically silence when he is just talking?
I found this, am I on to the right thing?
http://manual.audacityteam.org/man/tuto ... ation.html
Here are the raw audacity projects if anyone wants to look at them to help or just know what I am trying to explain. It is a part one and a part two with the corresponding directories that audacity created for each project. Basically it is just the first half the show and then the second half.
https://drive.google.com/open?id=0B7uF7 ... mVBTThyRGc
Thanks for any help anyone can provide or any links that would help! We have done a few shows before this and Audacity either did not pick up his audio on my end in previous shows or he was just so soft that it did not matter. However for this recent show, he is far too loud for him to work with joining the file with his audio in Garageband.
