extracting the features of music
jaleh
Post by jaleh » Fri Aug 26, 2016 8:54 am
Hi every body.
I want to know how can I get the features of a music by audacity? consist of pitch, tempo, amplitude and so on.
I need to change the rhythm or tempo of a music. How can I do it?
Re: extracting the features of music
Post by steve » Fri Aug 26, 2016 11:22 am
jaleh wrote:I want to know how can I get the features of a music by audacity? consist of pitch, tempo, amplitude and so on.
Not sure what you mean. The pitch, tempo and amplitude are all there in the music. What do you mean by "extract the features"? What are you trying to do?
jaleh wrote:I need to change the rhythm or tempo of a music. How can I do it?
The tempo can be changed with the effects:
Change Tempo (fast processing, but sounds echoey when slowing down the tempo)
Change Speed (like slowing down a record/tape, both the tempo and pitch change)
Sliding Time Scale / Pitch Shift (slow processing, but generally much better sound quality than the "Change Tempo" effect when slowing down the tempo)
For more information, see: http://manual.audacityteam.org/man/inde ... yzers.html
