recorded track plays back double speed [SOLVED]
Re: punch in or auto record
Post by Gale Andrews » Sun Aug 28, 2016 11:42 am
JC3 wrote:Thank you so much, I got it now.
So did new Zoom R8 drivers fix the speed problems?
JC3 wrote:I made a nice track and fixed some small mistakes by recording another track and then copy and paste into 1st track. I was wondering is there a way to punch in or auto record to fix small errors in a performance? cheers
Audacity does not have punch-in in the same track yet, except that if you hold SHIFT and click record then you can record at the end of the selected track(s).
You don't have to paste into the previous track. You can leave corrections in the new track, use Time Shift Tool to slide the correction into the best position, and if necessary crossfade the tracks so the joins between them are smooth.
Re: recorded track plays back double speed
Post by Gale Andrews » Tue Aug 30, 2016 12:19 pm
I split your question about opening an Audacity project to a new topic http://forum.audacityteam.org/viewtopic ... 46&t=92935.
So how did you solve your recording speed problem? It may help other users reading this to know. ;)
JC3
Operating System: Windows 7
Post by JC3 » Tue Aug 30, 2016 3:58 pm
Hi Gale, i was able to resolve the recording problem by going back to control panel -sound in my computer and rechecking the recording, play back settings. either I missed it or it moved:) but the recording setting was on 96hz. when I changed it to 44,1 things started to work right. thanks again
Re: recorded track plays back double speed [SOLVED]
Post by Gale Andrews » Tue Aug 30, 2016 5:38 pm
Thanks for confirming. OK, so given the problem has not come back, I will mark this topic [SOLVED] and lock it.
JC3 wrote:Hi Gale, i was able to resolve the recording problem by going back to control panel -sound in my computer and rechecking the recording, play back settings. either I missed it or it moved:) but the recording setting was on 96hz. when I changed it to 44,1 things started to work right. thanks again
