no volume on monitor or playback
kitkarken
Post by kitkarken » Mon Aug 22, 2016 6:06 pm
I have windows 10 and Audacity 2.1.2 and cannot record or monitor discs or tapes.
I have used the software before but now it doesn't work
kitkarken
Re: no volume on monitor or playback
Post by kozikowski » Mon Aug 22, 2016 6:22 pm
If you're devices connect by USB, make sure you connect everything and only then start Audacity. Audacity checks for connections when it starts. You can also try Transport > Rescan...
kitkarken
Post by kitkarken » Wed Aug 24, 2016 11:12 am
Thanks for that Koz, I will try that immediately.
Kitkarken
