The biggest problem 2.1.2 has that 2.1.1 does not is in "fit selection" (edit tool bar). Where it often proceeds to the next part of the song at end of the preview. It does stop but the "fit selection" is then off-screen ... where rewinding, scrolling back, etc., or replay is required to bring selection back into view.
Second is the Equalizer does not show Graphic mode sliders until switching to Draw mode then back to Graphic, when opening in Graphic mode.
Third I am not sure if it was me or the design, how when using Zoom tool, zooming in fast it would jump way ahead/way zoomed.. I've since read the manual and now much prefer the shotcuts anyway (key and mouse bindings): Control-Wheel, Shift-Wheel; Control-1, 3, e, and f. Awesome.
Hindsight: When fast in zooming I may have occasionally 'dragged', creating the jump forward --- This problem I consider solved and-my error, and I do not suggest changing this nice design.
Fit Selection & EQ bugs (in case ya didnt know)
Black Dog Bluez
- Operating System: Windows 7
- Quality Assurance
Re: Fit Selection & EQ bugs (in case ya didnt know)
Thanks for the reports. It is better to post bug reports in the board for your operating system, not in "Feedback and Reviews". This is so even if the bug turns out to apply to all operating systems. If we had a bug reporting board it would be different, but a lot of bug reports made are not bugs at all.
So I moved the topic for you.
Have you tried turning off "Update display while playing" in Tracks Preferences?
Can you provide exact steps 1,2,3... so we can reproduce the problem? Are you using Cut Preview (C shortcut)?Black Dog Bluez wrote:The biggest problem 2.1.2 has that 2.1.1 does not is in "fit selection" (edit tool bar). Where it often proceeds to the next part of the song at end of the preview. It does stop but the "fit selection" is then off-screen ... where rewinding, scrolling back, etc., or replay is required to bring selection back into view.
That one is known about and it will be in the Release Notes for 2.1.3 if not fixed: http://bugzilla.audacityteam.org/show_bug.cgi?id=1346.Black Dog Bluez wrote:Second is the Equalizer does not show Graphic mode sliders until switching to Draw mode then back to Graphic, when opening in Graphic mode.
Black Dog Bluez
No, not using thatGale Andrews wrote: Are you using Cut Preview (C shortcut)?
Yes, but prefer this on. Previous version did not have this problem, allowing both features simultaneously. But not using "Update display while playing", though undesirable, did fix the problem.Gale Andrews wrote: Have you tried turning off "Update display while playing" in Tracks Preferences?
BTW: Other bugs are, when trying/previewing/choosing settings of various effects they do not retain those settings. Example: Noise Reduction and EQ.. and others.
- Quality Assurance
Can you tell us the steps then? Which preview are you using? Generate a 30 seconds tone, or longer if necessary, then take us through how to make the problem happen from there.Black Dog Bluez wrote:No, not using thatGale Andrews wrote: Are you using Cut Preview (C shortcut)?
It could be it's already been fixed, but if not we need to know how to reproduce it.
Clearly that is not a general problem. I would suggest exiting Audacity then deleting pluginsettings.cfg.Black Dog Bluez wrote:Other bugs are, when trying/previewing/choosing settings of various effects they do not retain those settings. Example: Noise Reduction and EQ.. and others.
Thanks,
Black Dog Bluez
Sorry, "previewing" is just in reference to playing. As in simply playing a "fit selection" on Audacity.
I am using windows 7 on an HP 64 bit computer/offline - rolled back to factory condition with no microsoft updates..
Thanks, for the other problems, I'll also try deleting pluginsettings.cfg.
- Quality Assurance
OK, thanks for confirming. That's already fixed in our 2.1.3-alpha source code.Black Dog Bluez wrote:Sorry, "previewing" is just in reference to playing. As in simply playing a "fit selection" on Audacity.
In 2.1.2, CTRL + [ is a good way to bring the selection back into view. That will centre the left edge of the selection in the centre of the view.
