This is an infrequent problem, but its getting annoying. If I'm typing in a label name, there are times I am unable to type a "J" or a "K". Doing so exits me from the label text box and causes the cursor to jump to the start or the end of the file I'm working on.
Its definitely something I am doing, or something I forgot to disengage. What am I doing wrong? Thanks.
(Win7 Pro SP1 / Audacity Ver. 2.0.5 / .exe file)
AP in DC
CANT CREATE LABEL WITH 'J' OR 'K'
Re: CANT CREATE LABEL WITH 'J' OR 'K'
You need to update to a more recent version of Audacity. This problem was fixed a long while back.
The current version of Audacity is 2.1.2 and is available here: http://www.audacityteam.org/download/
