I have a percussion track I'm playing over and would like it to loop rather than having to extend the track.
How do I do that?
Windows 10
Audacity 2.1.0
Looped play through while recording
RussDodson
Re: Looped play through while recording
Apply the "Repeat" effect to the percussion track: http://manual.audacityteam.org/man/repeat.html
- Quality Assurance
