Audio shortens in camtasia
classifiedcat
Post by classifiedcat » Fri Aug 05, 2016 11:02 pm
Hi! In audacity, I have a track that is 6 seconds long. However, in my editing software, Camtasia, my track is actually only 4 seconds long. I exported it, but I don't know how to fix this error. Please help ^^
Re: Audio shortens in camtasia
Post by kozikowski » Sat Aug 06, 2016 3:27 am
Is the Camtasia track high-pitch and squeaky, or does it get four seconds into a regular clip and stop dead?
Post by Gale Andrews » Sat Aug 06, 2016 12:20 pm
Also what version of Audacity are you using? See the pink panel at the top of the page. And what format are you exporting to? Was the original audio recorded by Camtasia?
