Separate a guitar solo from song
beepmybrain
Post by beepmybrain » Sun Jul 31, 2016 9:07 pm
HI. I need to separate a guitar solo and paste it onto a separate track from the original song. How?
Re: Separate a guitar solo from song
Post by kozikowski » Sun Jul 31, 2016 10:20 pm
You could try Effect > Vocal Reduction and Isolation.
If that doesn't work then that's the end. Audacity has no good tools to split a mixed performance into individual instruments, sounds and voices.
beepmybrain
Post by beepmybrain » Mon Aug 01, 2016 1:07 am
Thx...but I managed to figure it out. I just highlighted what I didn't want, edit> cut. Wish I could have just copied the section I wanted, then pasted underneath the intact tract.
Post by kozikowski » Mon Aug 01, 2016 1:48 am
You can drag-select the work and press the wavy line in a vice tool.
Screen Shot 2016-07-31 at 6.46.19 PM.png (7.08 KiB) Viewed 1685 times
I think that has the effect of doing what you did with fewer edits.
