Unable to See File in Windows Media Player
Rosie44
Post by Rosie44 » Sun Jul 31, 2016 2:55 pm
I have created an Audacity file that I can view in my Music Library - however I cannot play it - nor can I see it in Windows Media Player. I was planning to burn it onto a CD - but cannot do so without using Windows Media Player. I was able to create an Audacity file previous to this which does appear in Windows Media Player and I was able to burn, so I cannot understand why this one doesn't. Thank you.
Reason: Correct typo in title
Re: Unable to See File in Windows Media Player
Post by steve » Sun Jul 31, 2016 3:48 pm
Did you "Export" form Audacity to create a WAV file? If not, you need to do that first, then use the WAV file to make the CD.
Detailed steps are shown here: http://manual.audacityteam.org/man/burn ... _a_cd.html
