Import Codec: Tracker file PCM S16 LE (araw) [SOLVED]
Hi,
I have a file extracted from a old Amiga game. It's a song that lasts 1 minute and 38 seconds. The file size is around 80KB !
I'm trying to convert this file into ogg but I can't import the file in Audacity. VLC can play the file and tells me the following codec:
Audio
PCM S16 LE (araw)
Stereo
44100 Hz
16bit
FFMpeg is already installed and detected by Audacity. Do I miss something else to import the file into Audacity ?
And I have to that I'm rather surprised about the file size (80kb) for a soundfile of that length.
regards,
Robert
Audio
PCM S16 LE (araw)
Stereo
44100 Hz
16bit
regards,
Robert
Reason: more accurate title
Re: Import Codec: PCM S16 LE (araw)
Me too.robberer wrote: And I have to that I'm rather surprised about the file size (80kb) for a soundfile of that length.
That should be:robberer wrote: It's a song that lasts 1 minute and 38 seconds
<snip>
Audio
PCM S16 LE (araw)
Stereo
44100 Hz
16bit
2 (stereo) x 16 (bits per sample) x 44100 (samples per second) = 140800 bits per second = 176400 bytes per second.
1 min 38 = 98 seconds
98 x 176400 / 1024 = (about) 17 MB.
Perhaps the file is a play list file that points to a 16bit PCM file.
Try opening the file in a plain text editor (such as NotePad) and see what happens.
Since VLC can play it, you should be able to convert to another format with VLC. There is some information here.
I did opening this in an hex editor. It starts with nice commentssteve wrote:Me too.robberer wrote: And I have to that I'm rather surprised about the file size (80kb) for a soundfile of that length.
Yeah, it's really strange. I guess VLC converts this file onDemand. What my be the real format ?
<snip>
Audio
PCM S16 LE (araw)
Stereo
44100 Hz
16bit
Yeah, I did, but the file extends to 1.6MB while converting it. Very odd.DVDdoug wrote:Since VLC can play it, you should be able to convert to another format with VLC. There is some information here.
- Quality Assurance
VLC's codec information is imperfect in my experience. It may be telling you what it decoded it to in order to play it.
That's not surprising to me... It depends on what format you converted to. That would be in the ballpark for an MP3, and Steve did the calculations for an uncompressed file (17MB). What format did you convert to?Yeah, I did, but the file extends to 1.6MB while converting it. Very odd.
It's the 80K file that's a mystery.
File *attached*. As the game disk is hosted to the public i think i can risk posting the file.DVDdoug wrote:That's not surprising to me... It depends on what format you converted to. That would be in the ballpark for an MP3, and Steve did the calculations for an uncompressed file (17MB). What format did you convert to?Yeah, I did, but the file extends to 1.6MB while converting it. Very odd.
- Attachments
- titel.wav
- I had to give wav extension to upload. But most probably it's not WAV
- (79.22 KiB) Downloaded 117 times
Wrong extension? What was the original extension?
Looks like a .mod or midi file to me. VLC seems to play both.
