Hi,
I just installed audacity and have been working on editing a podcast. For some reason, I can't save the session (not even save as... it's grayed out) nor import it. I've already worked on editing it so I'd be pretty sad if I had to restart.
Anyone can help? happy to provide more details about my system, screenshots etc.
can't save a project [SOLVED]
holytispon
- Operating System: Windows 7
holytispon
Re: can't save a project
Never mind. Problem solved. Nothing to see here. Carry on!
You pressed the "Stop" button?
holytispon
Re: can't save a project [SOLVED]
No, it was definitely stopped when I tried saving. Apparently my windows hasn't updated in a long while. I'm not sure it's related but now it lets me save.
