AUP file won't open in Audacity, please help!
Larry1Kenobi
Post by Larry1Kenobi » Fri Jul 22, 2016 1:58 pm
Hi there,
I'm currently using audacity 2.1.2 on Windows 10
I've tried to open my audacity project using the file>open command, to no avail... the program repeatedly prompts me to use the file>open command, which is what I'm doing. My other projects will open, no problem. This is what I have in my log:
14:43:33: File name is C:\Users\Lawrence\Music\raps\Ouija\9. Ouija Board (Prod. By CollegeBoii x The ScreamMaker).aup
14:43:33: Mime type is *
14:43:33: Opening with libsndfile
14:43:33: Opening with liboggvorbis
14:43:33: Opening with libflac
14:43:33: Opening with lof
14:43:33: Opening with libav
14:43:33: Error: Importer::Import: Opening failed.
14:45:39: File name is C:\Users\Lawrence\Music\raps\Ouija\9. Ouija Board (Prod. By CollegeBoii x The ScreamMaker).aup
14:45:39: Mime type is *
14:45:39: Opening with libsndfile
14:45:39: Opening with liboggvorbis
14:45:39: Opening with libflac
14:45:39: Opening with lof
14:45:39: Opening with libav
14:45:39: Error: Importer::Import: Opening failed.
I've been all over the internet looking for a solution and don't know where to go from here, could you please help me out?
Re: AUP file won't open in Audacity, please help!
Post by steve » Fri Jul 22, 2016 2:40 pm
Larry1Kenobi wrote:the program repeatedly prompts me to use the file>open command
What is the exact message?
Larry1Kenobi
Post by Larry1Kenobi » Fri Jul 22, 2016 3:21 pm
The exact message is as follows '[file] is an audacity project file. Use 'file>open' command to open Audacity projects', thanks in advance
Post by steve » Fri Jul 22, 2016 3:55 pm
Does it actually say "'[file]" or does it say:
"C:\Users\Lawrence\Music\raps\Ouija\9. Ouija Board (Prod. By CollegeBoii x The ScreamMaker).aup is an audacity project file.
Use 'file>open' command to open Audacity projects."
Larry1Kenobi
Post by Larry1Kenobi » Fri Jul 22, 2016 3:59 pm
It says C:\Users\Lawrence\Music\raps\Ouija\9. Ouija Board (Prod. By CollegeBoii x The ScreamMaker).aup is an audacity project file.
Post by steve » Fri Jul 22, 2016 4:07 pm
and you are definitely using "File menu > Open" and not "File menu > Import" or "File menu > Recent" ?
Larry1Kenobi
Post by Larry1Kenobi » Fri Jul 22, 2016 4:47 pm
Yes, without a doubt... I've used audacity in the past and familiar with it but this is the first time this has happened with a project
Post by steve » Fri Jul 22, 2016 6:39 pm
What's the file size of the AUP file?
Larry1Kenobi
Post by Larry1Kenobi » Sat Jul 23, 2016 12:03 pm
The AUP file is 61kb
Post by steve » Sat Jul 23, 2016 1:14 pm
Larry1Kenobi wrote:The AUP file is 61kb
That sounds about right. Please attach it to your reply and I'll have a look to see if there's anything peculiar about it.
See here for how to attach files to posts: http://forum.audacityteam.org/viewtopic ... 49&t=64936
