Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Levan
Post
by Levan » Thu Jul 21, 2016 6:02 pm
I am using audacity 2.1.2
So when i select the hard limit it gives me an error massage and point's me to the log
here is what i get in log
Code: Select all
21:56:05: Audacity 2.1.2
Log Cleared.
21:56:24: Error: Could not set current working directory (error 3: the system cannot find the path specified.)
21:56:24: Error: Failed to load shared library 'C:\Users\***\Desktop\Audacity\plug-ins\hard_limiter_1413.dll' (error 126: the specified module could not be found.)
So how can i fix this and i if there is an alternative that does the same job can you point me to it as well.
Levan on Fri Jul 22, 2016 1:51 pm, edited 1 time in total.
- Site Admin
Post
by steve » Thu Jul 21, 2016 7:36 pm
Hard Limiter has been replaced by a new Limiter effect. See:
http://manual.audacityteam.org/man/limiter.html
After restarting Audacity, the old "Hard Limiter" effect should be automatically removed from the Effect menu. If it isn't let us know and we can tell you how to remove it manually.
- Quality Assurance
Post
by Gale Andrews » Fri Jul 22, 2016 1:17 pm
Just to add that restarting Audacity will only get rid of the Hard Limiter menu entry if you have at least opened Effect > Add / Remove Plug-Ins... . So do that, ESC or Cancel to dismiss the Plug-In Manager dialogue, then restart.
Levan
Post
by Levan » Fri Jul 22, 2016 1:51 pm
Thank you for the replies guys, i found the effect and removed the hard limiter from the menu, thanks to you.
