My Audacity 2.1.2 is no longer working.
Wiki Waki
Post by Wiki Waki » Mon Jul 18, 2016 10:04 pm
I've been using Audacity 2.1.2 with Windows 10 for weeks now with no issue, however I sat down to record some audio with my normal set up and Audacity simply wouldn't record, I clicked the record button and got zero movement from my soundbar. I would appreciate any help that I can get. Below I've also posted a silent video that shows the issue, if I can provide more information to help just let me know.
Video: https://www.youtube.com/watch?v=bJASRGnIviU
Re: My Audacity 2.1.2 is no longer working.
Post by kozikowski » Mon Jul 18, 2016 11:50 pm
Before we get that far, what are you recording? Disco Mixer setup? Microphone?
Wiki Waki
Post by Wiki Waki » Mon Jul 18, 2016 11:52 pm
Microphone
Post by kozikowski » Tue Jul 19, 2016 2:05 am
Everything looks OK, so you're right out of my world. I'm not a Windows elf. We know there have been problems with Windows telling applications and drivers little fibs that cause recording errors.
You should go into Windows setups and make sure they're handling the hardware OK.
The error you got was starting a new recording while the first one was confused. It payed attention to the overdubbing settings at the wrong time.
You don't have to go into full record. You can right-click the meters > Start Monitoring. They will wake up and monitor the sound for as long as you want without making a recording.
Post by Gale Andrews » Tue Jul 19, 2016 1:12 pm
Wiki Waki wrote:I've been using Audacity 2.1.2 with Windows 10 for weeks now with no issue, however I sat down to record some audio with my normal set up and Audacity simply wouldn't record, I clicked the record button and got zero movement from my soundbar.
What is the make and model number of the microphone?
I would just do a cold boot to renew all the computer's resources. Windows key, click Power, hold SHIFT and click Shut down.
